Jay_Krew Posted March 27, 2024 Share Posted March 27, 2024 The problem I am trying to solve: I have created a custom set of steps and railings. I know what this to be the default for the plan and/or save the steps for future plans. I want to also use this so I can try out different versions of the steps in the dollhouse view to see which one I like best. How can I save custom stairs with materials etc. without having to recreate them or having to go to defaults and modify it there? I was sent the following article however this appears to be Chief Architect Premier specific as well: https://www.homedesignersoftware.com/support/article/KB-03015/adding-and-copying-objects-to-the-user-catalog.html. The first section of the article shares how to save objects in the plan to my User Catalog. This could help with adding quite a few types of items for future use to my User Catalog, but my concern here is saving steps in particular. If those steps are created using stairs, it appears that it is not yet possible to save stairs to the user library. The only way to use stairs I have created in another area of the plan is to copy and paste them in another area. Does anyone have any cleaver work arounds or point to something I may have missed? This seems like a pretty obvious pro user scenario IMHO. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 27, 2024 Share Posted March 27, 2024 Save the plan you like as a master. Then copy that plan and "save as" whatever you'd like to name it. Do that for as many variations as you want and your original stays unchanged Link to comment Share on other sites More sharing options...
Jay_Krew Posted March 28, 2024 Author Share Posted March 28, 2024 7 hours ago, Rookie65 said: Save the plan you like as a master. Then copy that plan and "save as" whatever you'd like to name it. Do that for as many variations as you want and your original stays unchanged Just to clarify, when you say "save the plan you like as a master", are you saying create all the default settings you want for that stair type (or any object) and then save it as an empty plan. From there, use that plan "type" with the default objects (materials etc.) setup in that specific plan. In a way the blank plan becomes a template for future use? Link to comment Share on other sites More sharing options...
Rookie65 Posted March 28, 2024 Share Posted March 28, 2024 Yes Link to comment Share on other sites More sharing options...
Robborito Posted March 30, 2024 Share Posted March 30, 2024 Why not this? Architectural Blocks An architectural block is a collection of individual 3D objects that are grouped together so that they can be placed and moved as a single object. Although blocked together, these objects retain many of their own attributes, such as materials.. See page 91 User Reference Manual. This is how I do it. Link to comment Share on other sites More sharing options...
