KilgoreRemod Posted March 12, 2024 Share Posted March 12, 2024 I created the curved wall by adding elevation lines and drawing a retaining wall, worked great. Then I added the workshop and the straight wall behind it. I have tried elevation lines, reversing layers, drawing the wall from left to right or right to left, elevation modifiers, and cannot make the straight wall behing the shop retain the high side and leave a 0 elevation walkway behind the shop. No matter what i do, the wall creates the 0 elevation area on the wrong side of the wall. please show me how to create that. Aaron Kilgore Windows 11 64 bit HD pro 2023 Back Patio.plan Link to comment Share on other sites More sharing options...
KilgoreRemod Posted March 12, 2024 Author Share Posted March 12, 2024 here is a 3d rendering, I need the flat 0 elevation side to be a walkway between the wall and the shop, opposite of the way this is pictured. workshop wall backward.pdf Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 13, 2024 Share Posted March 13, 2024 I played with it. What I did was add more elevation lines above this wall you want to ensure terrain remains So 120" on top edge of LOT and added them in every 2' elevation based on removing that wall of yours and having a nice uniform slope. Then I added your wall back as best as I could. But on the top side I put elevation line of what it roughly was before wall was there so I think I drew wall right ovcer the 6" elevation line and put that for elevtion line on top. ON bottm side of this wal lI added elevation line of 0.0 and made it a bit wider then garage and then added extended them vertically down along side of garage. See when you select the flat pad for foundation it does it for the house slab not other buildings I have found. So there are other ways you could make a FLAT AREA with 0 elevation around garage and then ensure you have enough elevation lines to define slope. 2 is not enough and the more the merrier as program interporlates between 2 lines and terrain item to try and figure out what the terrain would look like. So the only way to really ensure accuracy is draw in a bunch of elevation lines you know are accurate. Anyways play with what did. below 548429131_BackPatio.pdf 548429131_BackPatio.plan PS your garage roof is out of whack in that the ridge is not centered with building and the house wall is a tad higher than other hip side. Link to comment Share on other sites More sharing options...
KilgoreRemod Posted March 13, 2024 Author Share Posted March 13, 2024 thank you, i tried adding elevation lines and it made the ground a roller coaster in that area. Your drawing is what i needed it to look like, I will play with it some more and fine tune a little. Thank you again. Link to comment Share on other sites More sharing options...
