MississippiMims Posted December 12, 2023 Share Posted December 12, 2023 I have tried every setting I can find and have outworked my patience today. Can anyone tell me why my dormer walls are protruding through the roof? Genesis.plan Link to comment Share on other sites More sharing options...
Garybills Posted December 13, 2023 Share Posted December 13, 2023 I looked at it last night and all I could do was select both front walls at the same time, open the wall structure and checked default wall top. That cur the top of the walls but there are still issues with the bottom of the dormer walls leaving a gap between the dormer wall and the 2nd story wall. You can pull the bottom of the dormer wall down and close the gap. Link to comment Share on other sites More sharing options...
MississippiMims Posted December 18, 2023 Author Share Posted December 18, 2023 Thanks Gary. I also tried the "default wall top" and you are correct, it does fix the gable walls. But as soon as I make any changes, such as adding the porches, the walls revert back to protruding through the roof again. I don't know what's up with it leaving the wall short at the bottom. When you pull the wall down, it moves the window. Then when you try to move the window back to the correct position, it leaves an opening in the wall below the window. I think all of these issues stem from how the dormers where set up. I had to explode them to solve another roof issue I had with the main roof so I can't go back now. Dormers are so frustrating. I wish there was a "rendering" feature that would automatically clean up some of these issues. Thanks for your time. Link to comment Share on other sites More sharing options...
Garybills Posted December 18, 2023 Share Posted December 18, 2023 2 hours ago, MississippiMims said: Thanks Gary. I also tried the "default wall top" and you are correct, it does fix the gable walls. But as soon as I make any changes, such as adding the porches, the walls revert back to protruding through the roof again. I don't know what's up with it leaving the wall short at the bottom. When you pull the wall down, it moves the window. Then when you try to move the window back to the correct position, it leaves an opening in the wall below the window. I think all of these issues stem from how the dormers where set up. I had to explode them to solve another roof issue I had with the main roof so I can't go back now. Dormers are so frustrating. I wish there was a "rendering" feature that would automatically clean up some of these issues. Thanks for your time. Yeh, I seen they were exploded and then if you delete the walls and roofs it leaves the hole in the roof that you can’t do anything with. I don’t use the dormer tools much because they have issues. Link to comment Share on other sites More sharing options...
solver Posted December 19, 2023 Share Posted December 19, 2023 10 hours ago, MississippiMims said: Dormers are so frustrating. 1 Link to comment Share on other sites More sharing options...
Garybills Posted December 19, 2023 Share Posted December 19, 2023 Thanks Eric, for the video and reminding me of the roof opening being on its own layer! I was able to do what you did with HDP 2024 trial, Thanks again.  Link to comment Share on other sites More sharing options...
MississippiMims Posted December 20, 2023 Author Share Posted December 20, 2023 Outstanding information. I will spend some time learning to build dormers manually. I agree this is an easy roof to build manually but I didn't have the confidence in working with dormers manually to attempt it. I'm fixing to attempt the changes on HDP21. I'll update when I get it cleaned up. Thank you both for your generous time. Link to comment Share on other sites More sharing options...
Garybills Posted December 20, 2023 Share Posted December 20, 2023 Hey Wes, I have HDP 2021 on my computer, so I wanted to see if the tools were the same as the newer versions. They are a little different, but they are there. My wife is watching house hunters on tv, so I took a few minutes and made the changes as in Erics video and attached the plan. Genesis fixed in hdp2021.plan Link to comment Share on other sites More sharing options...
solver Posted December 20, 2023 Share Posted December 20, 2023 21 hours ago, MississippiMims said: but I didn't have the confidence in working with dormers manually to attempt it. Link to comment Share on other sites More sharing options...
MississippiMims Posted December 25, 2023 Author Share Posted December 25, 2023 Gary: The plan cleaned up nicely and I can now add porches without the dormers causing issues. Thank you. Eric: Once again, great information. I drew a quick practice plan to work with manual dormers after your first video. Doing dormers manually is much easier. I had so much trouble getting auto dormers to work initially until I figured out that placing them in the attic seemed to solve most of the issues. Auto dormers worked well unless they touched the front wall as these do. Thank you. Link to comment Share on other sites More sharing options...
