Janetcrouch Posted September 9, 2023 Share Posted September 9, 2023 I know I've done something silly to cause this when I was trying to adjust my roof angle to be close to my client's actual roofline. It's a remodel and I needed to make sure the roofline was in the correct place so I could figure out the heights of the kitchen cabinets. I did not draw the entire house because we are not remodeling the entire house, just a few parts. I try not to do extra work. Anyway, in making all the adjustments, I've done something to cause this space where my drywall doesn't go all the way up (or my roof doesn't come all the way down on the outside wall. I've tried adjusting everything I can think of to fix this, but I'm just not having any luck and I don't want to send a 3D view to the client like this. Can someone help? The ceiling is not exactly in the correct place, but I know the beams are very close. Kitchen.plan.zip Link to comment Share on other sites More sharing options...
Solution Garybills Posted September 9, 2023 Solution Share Posted September 9, 2023 Try selecting the room and raise the ceiling height by 4 inches. 1 Link to comment Share on other sites More sharing options...
solver Posted September 9, 2023 Share Posted September 9, 2023 What's the height of that wall -- floor to ceiling? What's the pitch of the ceiling/roof? With those 2 measurements, you can build an accurate model. 1 Link to comment Share on other sites More sharing options...
Janetcrouch Posted September 10, 2023 Author Share Posted September 10, 2023 Thank you Gary! That worked. Wow. That was easy. I'm not sure why the adjustments I made before did not work. Thank you Eric. I did try to do that. I'm not sure why it was giving me that problem. It seems to be fixed now. 1 Link to comment Share on other sites More sharing options...
