Highlandofficer Posted August 10, 2023 Share Posted August 10, 2023 i have downloaded the latest update for pro2024. Before the update when you highlighted a pocket door, a small arrow sign would appear with which you could change the direction that the door opened. (Not always easy, but one would get there in the end). This symbol has disappeared after the update. How can i now change the door opening direction? Link to comment Share on other sites More sharing options...
solver Posted August 10, 2023 Share Posted August 10, 2023 @Highlandofficer I just did the update. You don't see this? Link to comment Share on other sites More sharing options...
Highlandofficer Posted August 10, 2023 Author Share Posted August 10, 2023 Yes, many thanks for your reply. I see that diamond sign, but it does not seem to reverse the door direction. The diamond moves to the other side of the door, but the opening direction stays the same. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 10, 2023 Share Posted August 10, 2023 Go to the symbol of the door handing in the bottom tool bar and reverse the handing Link to comment Share on other sites More sharing options...
solver Posted August 10, 2023 Share Posted August 10, 2023 16 minutes ago, Highlandofficer said: but it does not seem to reverse the door direction I'm guessing you want to move the pocket to the opposite side of the opening. Link to comment Share on other sites More sharing options...
Highlandofficer Posted August 11, 2023 Author Share Posted August 11, 2023 Many thanks to you both, the solution seems obvious now. The short video was very useful. Link to comment Share on other sites More sharing options...
