Object Alignment (Ceiling Lights)
chadkee
Sorry, you can align ceiling lights using manual dimensions and what I also use is the "centering tool" you will find in the "Edit toolbar" when you select a light in plan view. I often center the first light and then center the other lights, one at a time to the one I just places where I wanted it. You can "marquee-select" a group of lights in plan view to move them all at once (all the above you can also do in many versions of Pro), I have been a Chief user since 1994, a teacher since 1999 and I know of nothing like you said Chief could do, Sorry.
  • 2 weeks later...
Along these same lines... I see the struggle to auto-align can lights...
What about auto-align or auto-space other objects such as floor joists?
Can I simply multi-select a number of items and then ask the program to space them all at 16"OC?
