chadkee Posted June 28, 2023 Share Posted June 28, 2023 Is there a way in Home Designer Pro to select multiple ceiling can lights and align them all at once. I know there is in the full Chief. Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 28, 2023 Share Posted June 28, 2023 Sorry, you can align ceiling lights using manual dimensions and what I also use is the "centering tool" you will find in the "Edit toolbar" when you select a light in plan view. I often center the first light and then center the other lights, one at a time to the one I just places where I wanted it. You can "marquee-select" a group of lights in plan view to move them all at once (all the above you can also do in many versions of Pro), I have been a Chief user since 1994, a teacher since 1999 and I know of nothing like you said Chief could do, Sorry. DJP Link to comment Share on other sites More sharing options...
Rookie65 Posted June 28, 2023 Share Posted June 28, 2023 You can try this link as a guide and modify to the particular room size you may have. It's a great help and simple to use. https://blog.recessedlighting.com/recessed-lighting-calculator/ 1 Link to comment Share on other sites More sharing options...
BoDay1 Posted July 12, 2023 Share Posted July 12, 2023 Along these same lines... I see the struggle to auto-align can lights... What about auto-align or auto-space other objects such as floor joists? Can I simply multi-select a number of items and then ask the program to space them all at 16"OC? Link to comment Share on other sites More sharing options...
Rookie65 Posted July 12, 2023 Share Posted July 12, 2023 Yes, transform/replicate. If you don't want to use auto framing and set it in your defaults Link to comment Share on other sites More sharing options...
