CarrieM Posted April 3, 2023 Share Posted April 3, 2023 Is there an automated way to square off measurements on room sizes, etc so that its not 16' 11 inches and 3/16? So maybe just 17 feet? I'm using home designer pro thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 3, 2023 Share Posted April 3, 2023 "Edit - (Menu) - Default Settings - Dimensions - Primary Format - Smallest Fraction", everything that happens, happens due to some Default Setting or dialog box setting, ALWAYS!!! DJP Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 5, 2023 Share Posted April 5, 2023 Yeah but purpose of computer drafting is you can be super accurate and find any issue before as we say the steel or in this case Wood is cut. If you designed and drew it and room ended up as 16'-11 3/16" then that is what it is and that can affect other rooms and roof etc by just saying round it up to 17ft. Better is to move the wall to what you want for dim. So click wall and it will show temp dims back to normally framing of other walls. Just click this dim and change the number to what you want. Watch what happens as you may have to ALIGN other walls or move things but now you have it drawn and can be dimension as you want 17ft and see what it affects. Design to exact numbers will reduce ON SITE problems. Like why does my cabinet not fit?. Sink does not fit? NOt enough room in front of toilet Door Molding does not fit so it has to be trimmed. So I do not suggest rounding - just design what you want. Link to comment Share on other sites More sharing options...
