Kristine Posted February 17, 2023 Share Posted February 17, 2023 Hi all. Is there a way to stop invisible walls breaking applied mouldings? I needed to define a room in order to alter the ceiling height so added invisible walls but one of them is breaking the base moulding in an adjoining hallway. The other invisible wall I added doesn't seem to be impacting anything. Thank you. Link to comment Share on other sites More sharing options...
scottharris Posted February 17, 2023 Share Posted February 17, 2023 Is it possible to post your plan Kristine? Link to comment Share on other sites More sharing options...
Kristine Posted February 18, 2023 Author Share Posted February 18, 2023 Thanks. It tells me my file is too large. I think there is a way to compress it but I'm not sure how? Link to comment Share on other sites More sharing options...
scottharris Posted February 18, 2023 Share Posted February 18, 2023 Kristine, it appears the alignment of your invisible wall for room definition is misaligned. I would first try to align the invisible wall according to the image I posted (A or B). Based on your 3D view, it appears one area has a ceiling the other does not. It that case an invisible wall takes on the properties of a 4” interior wall to correctly generate the attic walls above. Aligning the invisible wall to the other ‘visible’ wall is preferably done to the wall’s main layer (“A” in the diagram). It could be that issue as been resolved in a newer version (the plan I attached is Home Designer Pro 2023). Hope this helps! Room.plan Link to comment Share on other sites More sharing options...
Kristine Posted February 19, 2023 Author Share Posted February 19, 2023 Thank you. I did try that though it produces an undesirable overlap where the cathedral ceiling meets the adjacent wall. As you can see, the lower ceiling juts slightly into the area where I want the ceiling to be cathedral. Link to comment Share on other sites More sharing options...
CA-USER-DB Posted February 19, 2023 Share Posted February 19, 2023 Hello Kristine, while I understand that this might be undesirable from a design standpoint, it is a normal condition that I have seen more than once (see the photo of almost the exact same condition in my current home. It’s just the upper wall bearing on top of the top plate of the lower wall. Hope this helps. David B. Link to comment Share on other sites More sharing options...
