tdexter Posted June 24, 2022 Share Posted June 24, 2022 Is there a way in Home Designer Pro 2023 to create a kitchen wall cabinet on a gable wall so that the top of the cabinet matches the roof line? Link to comment Share on other sites More sharing options...
solver Posted June 24, 2022 Share Posted June 24, 2022 27 minutes ago, tdexter said: Is there a way in Home Designer Pro 2023 to create a kitchen wall cabinet on a gable wall so that the top of the cabinet matches the roof line? Needs to be done manually. Link to comment Share on other sites More sharing options...
tdexter Posted June 24, 2022 Author Share Posted June 24, 2022 Well, since I am only using the trial version of Home Designer Pro 2023, I saw no reason to add it to my profile. I have spent a half a day searching all of the mentioned resources, but found nothing that fits my needs. Thanks for trying. Link to comment Share on other sites More sharing options...
Rookie65 Posted June 24, 2022 Share Posted June 24, 2022 If it doesn't need the door to be angled, you could try going to the shapes library and place a wedge on top of the cabinet. Adjust the legs so it fills the gap between the top of the cabinet and your ceiling. Then you can change the wedge material to the color of your cabinets so it blends in. Link to comment Share on other sites More sharing options...
