tdexter Posted June 20 Share Posted June 20 I know this question has probably been asked a hundred times, but I cannot seem to find the answer. I am currently using Home Designer Suite 2019. I am considering upgrading to the latest version of Pro. My questions are: If I install the trial version will it disable my old version? If it does not disable my old version will I still be able to work and save in the old version? Thanks Link to comment Share on other sites More sharing options...
Solution Grechief Posted June 20 Solution Share Posted June 20 Trial version doesn't disable older version of the program and you will be able to save your work. Link to comment Share on other sites More sharing options...
solver Posted June 20 Share Posted June 20 2 hours ago, tdexter said: If I install the trial version will it disable my old version? No 2 hours ago, tdexter said: will I still be able to work and save in the old version? Yes Link to comment Share on other sites More sharing options...
tdexter Posted June 20 Author Share Posted June 20 Thanks! Link to comment Share on other sites More sharing options...
