CASeals Posted March 11, 2022 Share Posted March 11, 2022 This is my first time to use forum so hopefully I've correctly attached the file which has the camera view with my issue. In camera view I see a small section of framing which appears to be floating in air. I'd like to delete it, but it doesn't show up in my floor plan and I can't select it in camera view. Any advice will be appreciated. Thank you. Ali and Tad 031122 Revise Deck Outline.plan Link to comment Share on other sites More sharing options...
solver Posted March 11, 2022 Share Posted March 11, 2022 Only Pro has the ability to edit (select, delete etc) framing. And it's almost always helpful to attach a screen capture showing your issue. Link to comment Share on other sites More sharing options...
CASeals Posted March 11, 2022 Author Share Posted March 11, 2022 Eric, Thank you for your replies. I have just started with version Suite. I realize I will have some limitations but want to master as much as I can before spending more $. So far, I'm really liking the software. I have updated my signature to include my version. Hopefully you can now see it. Here's the camera view which has the floating beam I'd like to get rid of. Link to comment Share on other sites More sharing options...
solver Posted March 11, 2022 Share Posted March 11, 2022 6 minutes ago, CASeals said: I have updated my signature to include my version Thanks. Please add the year as well -- looks like you have 2022. Try Edit>Delete Objects Link to comment Share on other sites More sharing options...
