jdremo Posted February 7, 2022 Share Posted February 7, 2022 Hello There, I need some info on the shower door type I don't see that type of door in the library or a way to grab one from the library and customize to reflect that type of door now days people are using that type of door a lot which we call it rolling doors or barn shower door with one fixed panel and one that rolls on the bar above like in the picture. Is there any way to custom make that? The info will be very well appreciated. Thank you Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 7, 2022 Share Posted February 7, 2022 Take a look please DJP Link to comment Share on other sites More sharing options...
caf200 Posted February 12, 2022 Share Posted February 12, 2022 On 2/7/2022 at 2:04 PM, jdremo said: Hello There, I need some info on the shower door type I don't see that type of door in the library or a way to grab one from the library and customize to reflect that type of door now days people are using that type of door a lot which we call it rolling doors or barn shower door with one fixed panel and one that rolls on the bar above like in the picture. Is there any way to custom make that? The info will be very well appreciated. Thank you You can mash up something reasonably close. I used a regular shower and changed the frame to be 'tempered glass' in the materials. Then I put a towel bar in there and changed it's dimension to like 3"x3" and raised the height. Sometime manipulating by elevation view or something else can make it easier to grab bars and resize. I'm a rookie tho. Link to comment Share on other sites More sharing options...
