DaveDi Posted January 26, 2022 Share Posted January 26, 2022 Hi and thanks in advance... I am designing a closet where the ceiling is angled down on the right side from 96" to 81". I would need an open shelving unit, with a top, that is angled to conform to the ceilings drop. I searched but couldn't find online help so I am asking the forum for some help. Thanks - DD Link to comment Share on other sites More sharing options...
solver Posted January 26, 2022 Share Posted January 26, 2022 It's not clear what you want to do -- how the shelf unit is located in relation to the sloped ceiling. A screen capture (usually Vector View works best) of the area and maybe one showing the area on the plan would be helpful. You will need to model this from parts -- partitions, shelves, and probably a sloped soffit for the top. You can also make a thick wall -- here I used 24", insert a Wall Niche, change the shape and add cabinets/cabinet parts inside. Link to comment Share on other sites More sharing options...
DaveDi Posted January 26, 2022 Author Share Posted January 26, 2022 Here is a crude screen grab of what I am trying to do in a simple form. TY Link to comment Share on other sites More sharing options...
solver Posted January 26, 2022 Share Posted January 26, 2022 My suggestions above should get you there. Link to comment Share on other sites More sharing options...
DaveDi Posted January 28, 2022 Author Share Posted January 28, 2022 That worked! Thank you for your help. Is there a way to pitch downward a shelf? (higher of the left, lower on the right. Link to comment Share on other sites More sharing options...
solver Posted January 28, 2022 Share Posted January 28, 2022 21 minutes ago, DaveDi said: Is there a way to pitch downward a shelf? What are trying to do? On 1/26/2022 at 9:04 AM, solver said: You will need to model this from parts -- partitions, shelves, and probably a sloped soffit for the top. Link to comment Share on other sites More sharing options...
DaveDi Posted January 28, 2022 Author Share Posted January 28, 2022 This needs to be a fluid transition between Shelves on the left into the right. Would prefer not to use a niche. Would like to place an angled down shelf on top of shelves and partitions. Link to comment Share on other sites More sharing options...
