dspence Posted January 5, 2022 Share Posted January 5, 2022 I am new to this program and cannot get the wood flooring or ceiling to show in my 3D or or base design. I have tried everything I can think of and would like some help if possible. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 5, 2022 Share Posted January 5, 2022 "I have tried everything I can think of" doesn't tell anyone much, does it? And you haven't filled out your forum signature, either. Link to comment Share on other sites More sharing options...
dspence Posted January 6, 2022 Author Share Posted January 6, 2022 I guess the question should be how do I get the flooring and ceiling to show. When looking at it in 3D and in the base design, there are no options to see these two features. I have used the library browser to select the flooring I want and move it to the drawing however nothing happens. Link to comment Share on other sites More sharing options...
solver Posted January 6, 2022 Share Posted January 6, 2022 Looking at your image above, I imagine you have not created a room, you have simply drawn some walls. The program needs connected walls to form a room, so draw a wall here, and at the end of the hallway on the right -- a Room Divider will work. Link to comment Share on other sites More sharing options...
dspence Posted January 6, 2022 Author Share Posted January 6, 2022 Adding the room divider and setting the foundation to monolithic fixed my issue. Thanks for much for your help. I am using Home Designer Pro 2022 - build 23.3.0.81x64 Link to comment Share on other sites More sharing options...
