Merging a Terrain and Building Plan?
Darren
Hi
I've been creating a terrain plan from some data I have from the original survey of the property before the house was built
At the same time I have a plan I created using the PDF import, scaling  then drawing the walls on the PDF to get the base data
Is it possible to merge these so that the 'building' plan gets into the 'terrain' plan?
Maybe the answer is a copy and paste type function but I wanted to ask before I spent too many hours on it
Darren
It is programmed to create the structure in a plan file then ADD the terrain and orient the terrain TO the structure. If you need to indicate magnetic North relative to the structure you tilt the North Pointer relative to the existing building to get this done. You do NOT make them separate and then merge.
