henrys Posted February 14, 2015 Share Posted February 14, 2015 Good day! Please help me how to designed the structures of inclined walls outward @ 9 degrees with respect to vertical axis. slab level where shown on the attached drawing. Any good reply regarding this matter is highly appreciated. Thank you!inclined wall.pdf Link to comment Share on other sites More sharing options...
RobynKS Posted February 14, 2015 Share Posted February 14, 2015 Hi first you need to tell us what program you are using. It is best to add this to your profile. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 15, 2015 Share Posted February 15, 2015 I may get corrected but AFAIK neither HD of Chief can do Inclined Walls , it is a feature that has been asked for many times over the years , though not used by many so it has never been integrated into Chief's Products. There maybe a "workaround" for say a single wall , but not a whole building end as shown.... 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 23, 2015 Share Posted February 23, 2015 Slanted walls as such do not exist but much can be emulated using roof planes and skylights (skylights can be created on roof plane surfaces to create openings). If you want full creative freedom you will need a program like Archicad ($10,000.00) or learn to use Sketch Up where freeform custom creativity is supported. Chief and Home Designer are unbeatable for what they do and what they cost but they are for more traditional construction methods. DJP Link to comment Share on other sites More sharing options...
