mdag28 Posted July 27, 2021 Share Posted July 27, 2021 I want to add a rowlock brick edge to the top part of a brick base like the rowlock.png shows. The attached plan file and brick.png has the brick base and a column. I want the top row of bricks to be oriented for a rowlock. Is this something that can be done? Brick_base.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 27, 2021 Share Posted July 27, 2021 Use a Base Cabinet for the base of the column. Turn off the toe kick and make the front a blank area. Change the counter top thickness to about 3". Then assign a regular running brick course to the base cabinet and assign a soldier course brick that matches the running bond brick below. In Pro the brick material choices can be found in the Library Browser-Materials-Masonry & Brick - Brick. DJP Link to comment Share on other sites More sharing options...
mdag28 Posted July 27, 2021 Author Share Posted July 27, 2021 Thank you DJP! This works pretty well and simulates what I'm trying to do. Link to comment Share on other sites More sharing options...
Jo_Ann Posted July 27, 2021 Share Posted July 27, 2021 I think it's easier to use a soffit for the base. Size it correctly, and plop it down. A soffit also works better for the soldier brick course. Use the rainbow tool if the x / y position needs to be altered. The soldier course will now look correct on all four sides. 1 Link to comment Share on other sites More sharing options...
