chiefarch123 Posted July 3, 2021 Share Posted July 3, 2021 For some reason, the lights that I use in my project do not work (they do not turn on, even when I switch to phisically based rendering techniques). Could sb please tell me what is causing this problem and how to fix it? I'm new to this program, I only watched 2h worth of training materials. I'm using Home designer pro 2021. Untitled 1 — kopia.planFetching info... Link to comment Share on other sites More sharing options...
chiefarch123 Posted July 3, 2021 Author Share Posted July 3, 2021 Thank You for the reply, I attached my plan file. It's from a different project but with the same problem. Link to comment Share on other sites More sharing options...
Rookie65 Posted July 3, 2021 Share Posted July 3, 2021 I didn't see an attached plan, yet check what the materials are for the lights themselves in the item's settings. It's one of those things that started in the 2020 release where they didn't always default on, even with the setting be told to do so. When you open the materials, go to the "bulb" and make sure it's set with "lighting white" or whichever one you want to use. When it's been changed, it should then show. Link to comment Share on other sites More sharing options...
Jo_Ann Posted July 3, 2021 Share Posted July 3, 2021 Try opening their dialog box and turning them ON. Be sure to use a full camera for viewing. Link to comment Share on other sites More sharing options...
