pchristilaw Posted March 2, 2021 Share Posted March 2, 2021 Hello. I am a casual user. I can't find how to enclose the lower section of an outside deck. How would I enclose the area under the deck with a lattice or other type of material. Thanks in advance Link to comment Share on other sites More sharing options...
solver Posted March 2, 2021 Share Posted March 2, 2021 You should have at least 1 lattice material in the library, and you may have a lattice object. Link to comment Share on other sites More sharing options...
pchristilaw Posted March 2, 2021 Author Share Posted March 2, 2021 Hi Eric. Will get the signature built. I am running Home Designer Pro 2021 Build 22.3.2.55x64 June 2020. I see the lattice panel and 3 lattice materials. Not exactly what I wanted but it works. Cheers Link to comment Share on other sites More sharing options...
Rookie65 Posted March 2, 2021 Share Posted March 2, 2021 I will go the deck framing plan, transform/replicate the rim joists the thickness they are. Then edit them to keep the height the same, change the thickness to 3/4" or 1/2", then close the gap between the new joists and the framing. Then you can transform/replicate on the "Z" axis, adjust the thickness again if you wish. Then make that item a lattice. From a side elevation, you can adjust that piece to the height you need. Depending on what catalogs you have, there is a diagonal lattice that works pretty good. Just adjust the material and texture properties down to a size opening you want. Then you can even paint the material white or whatever color you want it to be. Link to comment Share on other sites More sharing options...
solver Posted March 2, 2021 Share Posted March 2, 2021 2 hours ago, pchristilaw said: Not exactly what I wanted but it works. What did you want? Done in Architectural because I had it open. 1/2" thick soffit with a lattice material rotated 45 degrees. Link to comment Share on other sites More sharing options...
RonDesigner Posted April 26, 2022 Share Posted April 26, 2022 I just created a new 1/2" thick bamboo lattice wall and saved it in the Wall tool. Now I can use it whenever and choose any color for it. Link to comment Share on other sites More sharing options...
