MokonBond Posted February 12, 2021 Share Posted February 12, 2021 I'm trying to do a roof in home designer suite but I am having issues. I've attached some screen shots. Basically I want a center portion of a building with hip walls along the front. There should then be two wings which the ridge line of the center portion join to. These two wings should have the gable wall facing the front. In the first attached screen shot you see the basic outline of the building along with an incorrect example. Basically what's wrong there is the wings are hip walls facing the front. The second screenshot shows what happens when I try to change those to gable ends. Does anyone know what I am doing incorrectly here? This is for home designer suite 2021 build 22.3.0.55x64 Link to comment Share on other sites More sharing options...
solver Posted February 12, 2021 Share Posted February 12, 2021 This? Link to comment Share on other sites More sharing options...
MokonBond Posted March 2, 2021 Author Share Posted March 2, 2021 no so here is a poor hand drawing trying to show this. Link to comment Share on other sites More sharing options...
solver Posted March 2, 2021 Share Posted March 2, 2021 22 minutes ago, MokonBond said: hand drawing trying to show this. Drawing is perfect Close Suite and attach your plan file so someone has something to work with. Link to comment Share on other sites More sharing options...
MokonBond Posted March 2, 2021 Author Share Posted March 2, 2021 thanks, here is what I was working with. house_web.plan Link to comment Share on other sites More sharing options...
solver Posted March 2, 2021 Share Posted March 2, 2021 Something did not work. Make sure Suite is closed. Link to comment Share on other sites More sharing options...
MokonBond Posted March 2, 2021 Author Share Posted March 2, 2021 opps thought I had, sorry, ive attached again house_web.plan Link to comment Share on other sites More sharing options...
solver Posted March 2, 2021 Share Posted March 2, 2021 Your drawing did not show the other side. What does it look like? Link to comment Share on other sites More sharing options...
MokonBond Posted March 2, 2021 Author Share Posted March 2, 2021 Yeah that's just about how I'm envisioning it but the center roof should extend all the way to the front of the building (e.g. there should not be that little flat part. What the key to getting it to build the roof as such? Thanks again for your help. Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 2, 2021 Share Posted March 2, 2021 Is this what you want? Link to comment Share on other sites More sharing options...
MokonBond Posted March 3, 2021 Author Share Posted March 3, 2021 yes Link to comment Share on other sites More sharing options...
Jo_Ann Posted March 5, 2021 Share Posted March 5, 2021 Try these settings, exactly, and see if it works for you. The cad lines are used, so that the wall breaks can be exact. 1 Link to comment Share on other sites More sharing options...
MokonBond Posted March 6, 2021 Author Share Posted March 6, 2021 Thanks you! this make sense. so its essentially adding the knee wall and pushing the hip wall over the breaks that do it it seems. I'll try this in a bit. One question is I put exterior walls in the interior dividing the two wings from the center of the house. Are these walls vital? Or could I use say a room divider as well? I most likely wont do this but just trying to understand better. Link to comment Share on other sites More sharing options...
