vwexpert Posted January 19, 2015 Share Posted January 19, 2015 How to show garage walls without sheetrock - just bare studs Link to comment Share on other sites More sharing options...
vwexpert Posted January 19, 2015 Author Share Posted January 19, 2015 Thanks Eric....somehow the forum lost my old signature info and shows me as a new member. Link to comment Share on other sites More sharing options...
vwexpert Posted January 19, 2015 Author Share Posted January 19, 2015 I tried a few different ways and this is the result Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2015 Share Posted January 19, 2015 did you build framing>walls ? Link to comment Share on other sites More sharing options...
vwexpert Posted January 19, 2015 Author Share Posted January 19, 2015 I tried working with this option...same issue Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2015 Share Posted January 19, 2015 post the plan perhaps , too much guessing..... perhaps messed up wall layers/wall definition , or material definition? M. Link to comment Share on other sites More sharing options...
solver Posted January 19, 2015 Share Posted January 19, 2015 I just tried it and only get the solid wood fill, no studs. Looks like a limitation of the software. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2015 Share Posted January 19, 2015 Nope , try harder ....... just joking, you must be tired Eric.... What's the most likely cause if you "can't see something" ??? especially if you "think" it should work..... That's right ......turn on framing in the 3D view in display options too..... Every view type has it's OWN display settings DBX I can see it is already on in the plan view in that pic of the DBX but you must enable it for the 3D view too and then rebuild the 3D with F12.... worked for me....in Pro...with the drywall removed in the wall definition. 1 Link to comment Share on other sites More sharing options...
solver Posted January 19, 2015 Share Posted January 19, 2015 then rebuild the 3D Link to comment Share on other sites More sharing options...
vwexpert Posted January 20, 2015 Author Share Posted January 20, 2015 Thanks...I will try it tonite Link to comment Share on other sites More sharing options...
Solution vwexpert Posted January 21, 2015 Author Solution Share Posted January 21, 2015 Ok...I went into Tools / Display Setting - put ck in Framing, walls. Hit the F12 button. Went into wall definition and removed inside sheet rock. Still have same problem. Ok now I fixed it. I had to go into Build / Framing / Build Framing / Wall - the put check into Build Wall Framing - Ok - F12 Thanks Eric and Mick Jim Link to comment Share on other sites More sharing options...
