RobynKS Posted January 18, 2015 Share Posted January 18, 2015 Hi I tried to do what you have explained to another home user . Your answers to his question and the video you made David were great. Many Thanks. However after I saved the log and the flooring to the name plus 90° I then checked my library and cannot find the new materials. So where did they save to? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 18, 2015 Share Posted January 18, 2015 Custom materials exist only in the plan file in which they are created unless you also add such a material to the Library Browser, only then is it available for other plans without making it anew in that plan. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted January 19, 2015 Share Posted January 19, 2015 if you saved it to your Library it would be in the folder called User Catalog .... Link to comment Share on other sites More sharing options...
RobynKS Posted January 20, 2015 Author Share Posted January 20, 2015 Hi Mick no it did not save to the user folders. David many thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted January 20, 2015 Share Posted January 20, 2015 Search the library using your File Name+90° , if it isn't found then either it didn't save or wasn't saved properly ,which means you'll need to try saving again to the library from the plan you created it in. If that doesn't work ,post the .plan file so one of us can have a look and advise further.. M. Link to comment Share on other sites More sharing options...
