DaveHicky Posted January 15, 2021 Share Posted January 15, 2021 (edited) Print Quality if I print layout save pdf quality is very poor if I screen shot and save to pdf on my Mac it’s ok first one print to layout \ pdf others screen shot to pdf P Mellor Proposed Amended test .pdf mellor view 1 pdf.pdf Rear Elevation pdf.pdf Rear Elevation pdf.pdf Edited January 15, 2021 by DaveHicky Link to comment Share on other sites More sharing options...
DaveHicky Posted January 22, 2021 Author Share Posted January 22, 2021 Can you tell me why live view detriates when you send to layout ? I want the quality of live view printed to layout and then to pdf . the same quality if you do a screen shot and send to pdf I think this is a fundamental necessity for the hole process to be able to print off acceptable drawings ! even if you set to plot options the there is still a lack of defined lines ,clarity Regards Dave Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 22, 2021 Share Posted January 22, 2021 Print quality is controlled by how you send your images to layout before printing. Vector View plan and camera views produce the sharpest images and lines. All the other camera types use Pixels and are thus the tend to "pixelate" when printed depending upon the resolution that you choose to send them to layout. For Cabinet Elevations, Exterior Elevations and details, I always use Vector view or Plot Lines settings before sending to layout for printing. Anything else, in terms of Construction Documentation is a waste of time. I use 3D view ONLY for design clients and NEVER or almost never for CD's as 3D views can and are often misunderstood by building professionals who are used to crisp-clear-easy to read 2D views and dimensions. DJP Link to comment Share on other sites More sharing options...
