WeebleSue Posted November 17, 2020 Share Posted November 17, 2020 First of all, I am using Home Designer Architectural 2015. Yes, I know, but I lost my job this year and can't afford the upgrade. Second, I have watched and watched and watched the 11:02 video on using moldings instead of soffits (????). I cannot figure out what he's trying to do, and he never shows the crown molding complete in the final room. I cannot use the example file he provided in the post as it was created in a newer version than I have. I watched the tutorial video but it did not answer my question. I have searched and searched the help documents but they are not helpful. OK, so I have a vaulted ceiling that I created using two soffits, as described in the help and manuals. I cannot get the crown molding to show, no matter what I select. Here is what I'm trying to create: Here's what my model shows: Here's the Molding definition of either soffit. I have tried offsets of various heights, from 3" to -3", both from bottom and from top, and still nothing. I pan up to see the top of the soffit, and the molding doesn't appear there either. What am I missing? the help says that if I attach a soffit to a wall, it will take the molding pattern of the wall. These are attached to my room walls where the crown molding definition is set. I have an additional soffit for the beam across the living room and ITS crown molding is showing fine. I have attached a zipped version of my model file. Thank you, Susan SCannonPlan.zip Link to comment Share on other sites More sharing options...
solver Posted November 17, 2020 Share Posted November 17, 2020 Moldings, I think, do not work on sloped soffits. Link to comment Share on other sites More sharing options...
solver Posted November 17, 2020 Share Posted November 17, 2020 10 minutes ago, WeebleSue said: I have watched and watched and watched the 11:02 video And what is the 11:02 video? Link to comment Share on other sites More sharing options...
WeebleSue Posted November 17, 2020 Author Share Posted November 17, 2020 Yours, regarding custom ceiling planes. Sorry, I didn't remember the name of the video and I didn't want to have to lose my post to search for it. Link to comment Share on other sites More sharing options...
