Adding grade beams under interior bearing walls
HowdyYall
Simple question, I think, but I have been trying to figure out how to do this for over an hour so far: with a monolithic slab with footings around the exterior and grade beams under load bearing interior walls, how do I make the foundation plan reflect the load bearing interior walls? Do I have to just draw foundation walls under the 1st floor reference or can I make individual walls "foundation walls", which will show up in the right places on the foundation plan. I have tried both ways and neither seems quite right. The former shows up on the foundation plan, but I am not sure if is centered correctly, and the latter doesn't show up at all on the foundation plan.
This would be very useful to the way I read plans when I build houses.
Thanks,
Tyler <><
Running HDPro 2021.
