ChiefJeet Posted September 14, 2020 Share Posted September 14, 2020 I wish to create wall piers as shown in the image. The pier size is 325x100 projecting out from the wall. The external wall thickness is 275mm and I try to break the wall so I can increase the thickness of it but it does not work. Please help. Attached the video showing my attempts and the plan file AppletonCrs22.plan Wall Piers Video.mp4 Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2020 Share Posted September 14, 2020 There are NO wall piers shown in your posted images that I am familiar with. What I do see is a brick wall with the door set to framing, thus insetting it relative to the surface of the brick. In your image from HD Pro you are showing siding 6 walls which is completely different from your brick veneer image photo. After watching your video, I think rather than trying to make walls do what they are not programmed to do, I would use a custom slab to create "wall piers". This would at least emulate them in-camera views and in plan view, they can be given a similar appearance by using the "Fill Tab" so they look like walls in plan view as well. DJP Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 14, 2020 Author Share Posted September 14, 2020 Thanks David Link to comment Share on other sites More sharing options...
