davaco Posted August 10, 2020 Share Posted August 10, 2020 When I used the material eyedropper to apply stucco to the exterior of an attic wall without checking the scope, all interior wall surfaces changed to stucco. As I was working on roof planes, wall alignment etc., I did not see this until after multiple important operations which I don't want to undo. What is the most expeditious fix for this? Trying to avoid editing material and texture on every interior wall. Help is much appreciated. Link to comment Share on other sites More sharing options...
davaco Posted August 11, 2020 Author Share Posted August 11, 2020 Thanks, I put the signature in. Just upgraded to HD Pro last week from 2015 and opened a previous plan. I suspect the defaults of the new version are the cause of my problems though the defaults should be plan specific. I always have problems when designing manual roof planes. Any insights on my undo material and texture issue? Link to comment Share on other sites More sharing options...
solver Posted August 11, 2020 Share Posted August 11, 2020 3 minutes ago, davaco said: Any insights on my undo material and texture issue? Select all the interior walls (shift select, marquee around etc) and change all at once. Link to comment Share on other sites More sharing options...
