CMU walls not displaying in framing overview
bbrother
Hi .  I'm having trouble getting the CMU walls to show up in the framing overview. this happens with full walls as well as a portion of a pony wall. As you can see all exterior walls are CMU and the front porch walls are pony walls with the lower wall being CMU. I looked at the wall defaults and it seems good to me. On the pony wall it only lets me show either upper or lower portions of the wall. Is that correct? Thanks for any help
Thanks for the tip on my signature. I meant to add that in my question, but forgot. Home designer Pro 2014. so if the CMU walls don't show up on framing overview, where will I find a view that shows the CMU walls with framing members? I'm doing a small project that I need drawings for the permitting process.
Thanks again
I believe you need to start with a standard Perspective Overview and change things to show as you want.
For your wood framed walls, you would create a new wall type without drywall and turn on the wall framing layer so it shows.
