Kristine Posted July 17, 2020 Share Posted July 17, 2020 What is the best way to go about recreating this exterior in terms of the areas which are raised (brick) and recessed (siding)? Particularly the areas of siding above the lower ground windows. I originally drew it out roughly with regular straight exterior walls then realised when I went to apply materials that I'd missed the variation in depths. Played around with some options though just ended up making a mess! Any help appreciated. Thanks. Link to comment Share on other sites More sharing options...
solver Posted July 17, 2020 Share Posted July 17, 2020 What are you trying? Link to comment Share on other sites More sharing options...
Kristine Posted July 17, 2020 Author Share Posted July 17, 2020 Thanks. Have you just off-set the walls? I can play around with this though I'm still not sure how to achieve the recessed siding areas above the ground level windows? Link to comment Share on other sites More sharing options...
solver Posted July 17, 2020 Share Posted July 17, 2020 On 7/17/2020 at 12:44 AM, Kristine said: Have you just off-set the walls? Expand No. A brick wall is thicker than one with siding. You could also try a Custom Backsplash. Link to comment Share on other sites More sharing options...
Kristine Posted July 17, 2020 Author Share Posted July 17, 2020 Sorry, I mainly use the program for interior decorating (so purely visual) and aren't very familiar with exteriors. I usually just paint materials on which doesn't effect thickness. So I need to set the wall material somewhere? Link to comment Share on other sites More sharing options...
solver Posted July 17, 2020 Share Posted July 17, 2020 Using a Custom Backsplash will probably be easiest for you if you are just going for looks. Lots of how to articles and videos on the Home Designer website, and the Chief Architect YouTube channel (look for the Home Designer ones). Much new to learn when doing exteriors. Link to comment Share on other sites More sharing options...
Kristine Posted July 17, 2020 Author Share Posted July 17, 2020 Thanks so much. I really appreciate your replies. Link to comment Share on other sites More sharing options...
