Fill Patterns to Cross Sections
ChiefJeet
5 minutes ago, ChiefJeet said:
using Cad to enhance the section.
That's what you do.
Can the fill patterns same as on the floor plan be applied to sections?
Only manually as filled CAD.
Thank you Eric.
The section in the clip is taken through the window but in the background, there is a solid fill, perhaps the door in the background. How can I clean the section so only entities the section is cutting across are visible and then I would be able to hatch the walls?.
YareGrove5.plan
