Default font not applied to new rooms
davidstvz
I have a plan for which default fonts are still at defaults (all 6 text styles in the "default settings" dialog are using the Chief Blueprint font as they should).  However, when I create new rooms, or delete a label then restore it for a room (or delete and restore living area) Arial font at size 6" is used.  If I click the newly re/created label, I can edit the text style or instruct it to use the defaults.
Why are new labels being created without using the default settings?  How can I fix it?
Yes.  The Room Label Style is definitely just like that.  Again, if I click a label and "open object", I can select "Text Style" then click the box for 'Use Default Text Style: "Room Label Style"'
So I guess the problem is that the new labels, by default, aren't being created with this check box for using the default style checked.  It's kind of a weird catch-22.
