KilgoreRemod
I have read through the help manuals and tried several things, and cant seem to find the right button.  This is something that I will end up doing quite often, and a little help would be much appreciated.  I need the half glass pony wall in front of the shower to be tile on the edge, the bottom section of the same wall in the shower door opening to have a tile top, and I need to put in a solid bench seat at the right end of the shower.  From what I have read on the bench seat, it has to do with foundation settings to basically pull the floor up, but everything I have tried has been unsuccessful.  Final goal is a tile shower wall with a tile border wrapping the opening on the outside of the shower by about 4".  on the same note, I would like to draw in inset shelving in the shower walls, have not even attempted that yet.
Thank you in advance,
Aaron Kilgore
Kilgore Remodeling Services, LLC
Home Designer Pro 2021
Windows 10
vossler.plan
