Both wall ends resize at the same time
Carol_R
In "Edit - Preferences - Edit - Behaviors" in Home Designer Pro 2015 (and older versions as well) there is a setting for "Edit Type", the ones listed there are: "Default (where it should always usually be selected), Alternate, Resize, Concentric (which includes a "Jump" input box to control how much something resizes concentrically) and "Fillet". Each of those settings and their specific purposes are fully described in your Reference Manual as to why one might use them temporarily.
If you changed any of them but especially "Concentric" could also directly cause the behavior you are seeing, check and see. Without knowing which software application you are using, it is a guessing game for us as to why you are getting unwanted behavior.
