GLOBE-Res Posted March 10, 2020 Share Posted March 10, 2020 Ok folks, put your thinking caps on. I'm trying to get my rendering to "spin". I can get it to work, sometimes, but it's trial and error. Is there any setting or method to use to do this with greater accuracy? Link to comment Share on other sites More sharing options...
solver Posted March 10, 2020 Share Posted March 10, 2020 I seem to have the opposite problem -- spinning when I don't want it. I once suggested that spin speed be selectable. Don't know of any way to control things. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 10, 2020 Author Share Posted March 10, 2020 Aggghhh, I got it to spin! I don't know what I actually did other than drag and let go. I seem to be able to spin faster or slower by dragging faster or slower but it is haphazard and not easily repeatable. Any thoughts? Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 10, 2020 Author Share Posted March 10, 2020 Ok here's another issue. How do I get the Home Designer Core Catalogs for my laptop? 1 Link to comment Share on other sites More sharing options...
solver Posted March 10, 2020 Share Posted March 10, 2020 1 minute ago, WILL_in_PGH said: I actually did other than drag and let go. That's all you do. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 10, 2020 Author Share Posted March 10, 2020 Oh good grief. Thank you! Link to comment Share on other sites More sharing options...
ricatic Posted March 11, 2020 Share Posted March 11, 2020 I have found that with a bit of try and try again I can get the rotation speed way down...i just drag it like I just want to move it a bit and after a couple of drags it spins real slow...its easy to get it to spin fast... Regards Rick Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 11, 2020 Author Share Posted March 11, 2020 yes, I too have worked with the trial and error method but I was hoping for an actual button to click for a more precise and consistent action, no such luck I'm finding. Link to comment Share on other sites More sharing options...
solver Posted March 25, 2020 Share Posted March 25, 2020 On 3/10/2020 at 8:42 PM, WILL_in_PGH said: yes, I too have worked with the trial and error method but I was hoping for an actual button to click for a more precise and consistent action, no such luck I'm finding. Control-Alt-S will start the spin. Any keypress will stop it. Control-Alt-S again spins in opposite direction. Open the camera and change the Incremental Rotate Angle to set the speed -- small angle like .5 for slow, higher numbers for faster. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted March 25, 2020 Author Share Posted March 25, 2020 How the He** did you figure this out?! This is absolutely incredible. Well done. I tip my hat to you. Link to comment Share on other sites More sharing options...
