BrewerDesign Posted March 5, 2020 Share Posted March 5, 2020 Using HD Pro 2020 I'm trying to flip a modified slab about the X axis. I'm making a privacy screen and this would a trellis-like board across the top. I've searched CA libraries and 3D warehouse and can't find what I want. I searched Home Talk and found a post by Solver where he suggested you should get a rotation handle in an elevation. I've tried cross section, back clipped and elevation views with no luck. And of course all the poly line tools are grayed in these views. Thanks, Dennis Trellis Top.plan Link to comment Share on other sites More sharing options...
hward01 Posted March 5, 2020 Share Posted March 5, 2020 I'm not sure if I understand your question but if your objective is to create a beam that has an ogee cut on the ends? I would do that using the soffit tool. Link to comment Share on other sites More sharing options...
solver Posted March 5, 2020 Share Posted March 5, 2020 You can only rotate a slab in plan. What are you trying to do? Link to comment Share on other sites More sharing options...
BrewerDesign Posted March 5, 2020 Author Share Posted March 5, 2020 Thanks for the response! I want to create something similar to this: Link to comment Share on other sites More sharing options...
solver Posted March 6, 2020 Share Posted March 6, 2020 Use a Custom Backsplash. Here is a video to get you started. Watch on YouTube: https://youtu.be/edhaV2f_Ucc 1 Link to comment Share on other sites More sharing options...
BrewerDesign Posted March 6, 2020 Author Share Posted March 6, 2020 Great idea. Thanks Eric and thanks hward01 for responding - try custom backsplash - you get the poly line tools in elevation views! Thanks, Dennis Link to comment Share on other sites More sharing options...
