SSnygd Posted January 14, 2020 Share Posted January 14, 2020 My ceiling is rendering at much lower than my specified heights. In the photos, you can see that the ceiling (93") is lower than my windows with top heights set at 87". If any one has suggestions on what I may be doing wrong or what I should try next, I would appreciate it. Link to comment Share on other sites More sharing options...
solver Posted January 14, 2020 Share Posted January 14, 2020 It's usually helpful to post the plan file. Close the software first. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 14, 2020 Share Posted January 14, 2020 Open one of those windows and post a pic of the dialog settings box. Link to comment Share on other sites More sharing options...
SSnygd Posted January 14, 2020 Author Share Posted January 14, 2020 Eric, Thanks so much for the tips on getting started posting. See plan attached. I have spent quite a bit of time trying to search through the Help system without luck. Perhaps I am not using the right search terms? Really appreciate any insight. HDA_SSnygd_1-20.plan Link to comment Share on other sites More sharing options...
solver Posted January 14, 2020 Share Posted January 14, 2020 Link to comment Share on other sites More sharing options...
solver Posted January 14, 2020 Share Posted January 14, 2020 You can use Edit>Reset To Defaults to clean things up. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 14, 2020 Share Posted January 14, 2020 On the top tool bar: Edit>Default Settings>Floors and Rooms>Current Floor. Set your ceiling height. Do this for each floor. If it doesn't auto reset, then ... On the top toolbar: Edit>Reset Defaults. Put a check mark in All Floors, Ceiling Heights, and Floor Heights. Link to comment Share on other sites More sharing options...
SSnygd Posted January 14, 2020 Author Share Posted January 14, 2020 Perfect! Thank you both for your quick help!! Link to comment Share on other sites More sharing options...
