4ndrew Posted December 22, 2019 Share Posted December 22, 2019 Hi all, There are a few foundation height questions about varying them, but I didn't find any that seem to address what I'm looking for. Basically, I'm trying to figure out if/how we can have foundations at different heights for non-connected structures, then connect them with stairs/ramps later. This would come in handy on a sloped lot, for example. Ideally, I'd like to change nothing in the structure except the bottom-most elevation (height) of the foundation. For example, I draw a structure. Then, I want to draw another, not connected to the first, 3 feet lower. And, in addition, change the vertical location of an entire structure. So far, I haven't discovered a way to do this. Might be simple but as with some other things I don't know what command/menu item to look for. Link to comment Share on other sites More sharing options...
solver Posted December 22, 2019 Share Posted December 22, 2019 Foundations are rooms. Open it and adjust as needed. Link to comment Share on other sites More sharing options...
4ndrew Posted December 22, 2019 Author Share Posted December 22, 2019 13 minutes ago, solver said: Foundations are rooms. Open it and adjust as needed. Morning Eric - I didn't find any single "height adjustment" that allows me to make a change & updates all related numbers automatically. For example, I can drop the foundation, but the ceiling stays in the same place. In other words, if I know the 2nd structure I'm drawing has a foundation bottom 36" lower than that of the first, can I somehow get HDP to recognize that, and base the structure I'm working on on that new 36" lower height? (red line is the elevation for which I'd like to drop the base 36".) \ I thought I might be able to figure something out using different floors, but with my limited knowledge, that was a bigger mess. Link to comment Share on other sites More sharing options...
solver Posted December 22, 2019 Share Posted December 22, 2019 The software thinks about the floor height for the first floor. It builds the foundation down from there, and the rest of the structure starting there and going up. Link to comment Share on other sites More sharing options...
4ndrew Posted December 22, 2019 Author Share Posted December 22, 2019 This is what I'm saying - yes, I can adjust that, but the ceiling stays where it is. I suppose there's no way to lock everything so that I can adjust a single height somewhere & have everything else follow along? Not sure what's going on in your pic, but when I lower the floor of the building on the right, here's what I get. I want the -entire- structure to drop by 100". Link to comment Share on other sites More sharing options...
solver Posted December 22, 2019 Share Posted December 22, 2019 19 minutes ago, 4ndrew said: I suppose there's no way to lock everything so that I can adjust a single height somewhere & have everything else follow along? Nope. It's a bit frustrating, I know. Just reset the other settings to their defaults working from the top down. 1 Link to comment Share on other sites More sharing options...
4ndrew Posted December 22, 2019 Author Share Posted December 22, 2019 Got it, thanks. Link to comment Share on other sites More sharing options...
