LindaM Posted September 14, 2019 Share Posted September 14, 2019 I am trying to create ceiling decorative beams with a soffit. I cannot get rid of the molding and saw in another thread to use a "slab" instead of soffit, I'll try this. However, I cannot get rid of the trim in my 3d view now, the soffit is gone but the trim is not and I can't get my cursor to even recognize this to delete. Thanks in advance! Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2019 Share Posted September 14, 2019 Are you using a "Template Plan" that has crown mold in all of its rooms? Please post a copy of your plan file for others to inspect and thus help more specifically DJP Link to comment Share on other sites More sharing options...
LindaM Posted September 14, 2019 Author Share Posted September 14, 2019 I seem to have gotten rid of it somehow, no idea how. When I went into plan view and back to 3D view it was gone. What is the best way to create decorate beams? Thank you! Link to comment Share on other sites More sharing options...
LindaM Posted September 14, 2019 Author Share Posted September 14, 2019 And yes, I am using a template plan that has trim. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 14, 2019 Share Posted September 14, 2019 I have a trial copy of Pro 2020 and used a template plan file which had, by default crown moldings and got the same results you did when placing soffits for beams. I then went to "Edit - default settings-floor one-moldings tab" and turned off crown mold and then after that, no crown mold appeared anywhere. it seems to be all or nothing in Pro. DJP Link to comment Share on other sites More sharing options...
LindaM Posted September 14, 2019 Author Share Posted September 14, 2019 I have been procrastinating upgrading! I did deleted the crown feature in my plan view for the room and it worked also. Thanks so much! Link to comment Share on other sites More sharing options...
