LindaM Posted June 9, 2019 Share Posted June 9, 2019 I'm setting my defaults and the exterior wall material isn't being reflected on my second floor walls. The material is showing up in the wall type layer section but not on my 3D, what am I doing wrong? I've tried manually changing it from the 3D view and it's not working here either. I'm getting siding instead of brick. Thank you. Link to comment Share on other sites More sharing options...
solver Posted June 9, 2019 Share Posted June 9, 2019 Try opening a wall and setting it to use default (check the box). Post plan if this does not work. Link to comment Share on other sites More sharing options...
LindaM Posted June 9, 2019 Author Share Posted June 9, 2019 It opens to the correct material. Link to comment Share on other sites More sharing options...
