Window Glass Transparency
Paul715j
14 minutes ago, solver said:
Which rendering type are you using?
Standard, vector ...
Only Standard will show transparent glass, but can be set to show opaque glass -- see Technique Options.
You might have painted the glass too. Check Materials on a window and make sure it shows correctly.
This is from Chief so it shows more options than Pro.
Looking in 3D View Defaults on Backdrop Standard is ticked.... how do you see Technique Options?  I've gone into the library but can't seem to alter or see the properties of the Glass - Standard or am I doing something wrong?  As you can tell not long had it! sorry.
