Fredo649 Posted April 16, 2019 Share Posted April 16, 2019 I am trying to build a story and a half home with bedrooms and such on the upper floor . Built the lower walls no problem 9' ceilings then did the roof plains 8/12 pitch that worked well but ended up with no floor for the upper bedrooms so I drew in 2 1/2" I-Joist above but still no floor and it looks like all the doors and interior walls are building off the lower ceiling drywall . Help , What did I do wrong ? Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 Did you build a 2nd floor? You cannot build rooms on the Attic level. Link to comment Share on other sites More sharing options...
Fredo649 Posted April 16, 2019 Author Share Posted April 16, 2019 If I build a second floor it puts in 8' walls, how do I get around that ? It's been a long day and I can't seem to wrap my head around this. Link to comment Share on other sites More sharing options...
solver Posted April 16, 2019 Share Posted April 16, 2019 8 minutes ago, Fredo649 said: If I build a second floor it puts in 8' walls, how do I get around that ? That's the default. When you build the 2nd floor, you have the ability to make the ceiling height (and wall height) whatever you want. Using auto built roofs, you will need to turn them off and raise the ceiling height. You can build the roof and set Ignore Top Floor. It depends on how the home will be built. Will the roof sit on the 1st floor walls or on the 2nd floor deck? Just think about how the program works and how and where it builds roof planes. Also, search the Home Designer website for Cape Cod. Link to comment Share on other sites More sharing options...
Fredo649 Posted April 16, 2019 Author Share Posted April 16, 2019 Thanks I'll see what that does. But not today my brain is pooched. Link to comment Share on other sites More sharing options...
