SeabeeMike Posted April 3, 2019 Share Posted April 3, 2019 I was well underway on a plan before I realized I was drawing with the front door at the top of the plan instead of the customary bottom of the plan. I rotated the entire plan 180 degrees and now find that my X and Y axis are reversed. If I move an object +12" it moves left, rather than right. Same for Y axis, down instead of up for positive value. Seems like there should be some way to tell HD that the plan was rotated and act accordingly! Thanks, Mike Link to comment Share on other sites More sharing options...
solver Posted April 3, 2019 Share Posted April 3, 2019 How did you rotate? Best way is using Edit Area. Link to comment Share on other sites More sharing options...
SeabeeMike Posted April 3, 2019 Author Share Posted April 3, 2019 Selected all then used the rotate triangle & manually rotated everything. Link to comment Share on other sites More sharing options...
solver Posted April 3, 2019 Share Posted April 3, 2019 Try reversing your steps rotating back 180, then use Edit Area>Edit Area (All Floors) to rotate. 1 Link to comment Share on other sites More sharing options...
