CoachRob14 Posted April 4, 2019 Author Share Posted April 4, 2019 Wow- For crying out loud, I figured it out. My Floor Height (Floor C) was at 48". I dropped it down to 0, and now I am where I need to be. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 4, 2019 Share Posted April 4, 2019 Put in your grade so you have a reference point. It is done by setting a distance below floor 1. In your case, would probably be whatever the basement level is, then 4" lower possibly to allow for the step down often needed. Then since the garage is its own room, you can drop the level of that to grade. Or if you don't want to have the garage defaults take over, leave the room defined as a "basement" and change the display to show "garage". Then when you open that one room you can drop the floor lower to meet grade. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 4, 2019 Author Share Posted April 4, 2019 So final step... Entrance way stairs No idea even where to begin- how do you start a staircase, inside of a doorway that is technically suspended between two floors? It's almost like I need to create a separate "floor" just for this entrance way. Link to comment Share on other sites More sharing options...
solver Posted April 4, 2019 Share Posted April 4, 2019 On 4/4/2019 at 5:05 PM, CoachRob14 said: It's almost like I need to create a separate "floor" just for this entrance way. Expand Give that a try, or use a landing. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 4, 2019 Author Share Posted April 4, 2019 just don't know how I create a "floor" in that one spot, that doesn't span the length of the entire house! Also, I already dedicated "Floor 1" to be the living area- with this idea, I will need to call that "floor 2". How the heck do I transfer everything I did on "floor 1" and now label it as floor 2? ughhh Link to comment Share on other sites More sharing options...
solver Posted April 4, 2019 Share Posted April 4, 2019 The software, and general public use floor to be what you stand on, and as the level of the structure -- ground floor, 1st floor etc. Imagine your 1st floor has the same floor (standing on) level everywhere. Now you want to drop a section of that floor down so that it aligns with the front door. The other part of that space will be Open Below to make room for the stairs to the basement. 1 Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 4, 2019 Author Share Posted April 4, 2019 I fully understand what you are saying. I just don't know how to isolate that one section of floor to drop it down Link to comment Share on other sites More sharing options...
solver Posted April 4, 2019 Share Posted April 4, 2019 Rooms control floor and ceilings heights, so create a room -- use a Room Divider wall, where you want the landing. Then give the floor in that room a negative value so it moves down and aligns with the door. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 4, 2019 Author Share Posted April 4, 2019 Getting so much closer!!!! I was able to drop the floor in that one location!!! I think I dropped it to 96". And I was able to use the glass house view to align the front entrance door in correlation. Now, when I try to "open up the stairwell", I am getting a message that it "can not find the floor above"? Home_Designer_Suite_2019_4_4_2019_7_38_14_PM.mp4 Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 5, 2019 Author Share Posted April 5, 2019 Wow I can't believe it. I FINALLY got what I was looking for!!! I am sure there are flaws in it! I am sure the dimensions are not proper or possibly not realistic- I don't know how it affected walls to the left or right, or the bottom level where there should be storage under this stairwell. But i FINALLY got a raised ranch stairwell!! Well, at least half of it. I need to work on the other side that goes down into the lower level. I dropped the floor (Floor C) to 84"- I'm not sure if that is "building realistic", but it seemed to do the trick! Link to comment Share on other sites More sharing options...
