RandyNavarro Posted November 11, 2014 Share Posted November 11, 2014 Using HD Pro 2012. I can create a double stud exterior wall and create a plan just fine; two 2x4 walls with 1" space between. I then add a conventional 2x6 stud wall for the attached garage. The corners of the two dissimiliar walls don't wan't to line up. Also, the interior dimensions dimension to the "Main Layer" which is the outermost 2 x4 wall which does not create accurate interior measurements. Any ideas how to get everything to line up? Link to comment Share on other sites More sharing options...
solver Posted November 11, 2014 Share Posted November 11, 2014 Post an image, or better, the plan. You may also be interested in a thread I started. https://hometalk.chiefarchitect.com/index.php?/topic/419-framing-not-showing-in-self-defined-wall/ Link to comment Share on other sites More sharing options...
Kbird1 Posted November 11, 2014 Share Posted November 11, 2014 Did you draw the double wall as two separate walls , or did you define a new wall type with the 2 framing layers ? HD uses the "Main Layer" to control / define a number of things like how/where walls join , so in this case it may be easier to define the Exterior wall studs as 8" instead of a 3 1/2" 2x4 (3.5" +3.5"+1" gap=8" total) so everything joins and dimensions easily. M. 1 Link to comment Share on other sites More sharing options...
RandyNavarro Posted November 12, 2014 Author Share Posted November 12, 2014 I followed the link to solver's thread and saw the YouTube video by David Potter. Looks like the only way to do it is to manually draw two walls. Thanks for the responses. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 13, 2014 Share Posted November 13, 2014 Lots of info in that thread , windows and doors are a PITA with double walls though. M. Link to comment Share on other sites More sharing options...
