Bretkennedy74 Posted February 4, 2019 Share Posted February 4, 2019 I am using the Jute Vanity pictured below, with a custom countertop on top of the vanity, but no matter what I try, I am unable to install an undermount bathroom sink into the equation, any ideas what I need to do/adjust? I have tried removing the counter top also. Link to comment Share on other sites More sharing options...
Bretkennedy74 Posted February 4, 2019 Author Share Posted February 4, 2019 can you do me a favor and stop just reply with this message? it gets really annoying. I have already said in my profile that I am using Home Designer Pro. I am on the HomeTalk Forum, the answer shouldn't be that difficult for people who have been using the software for longer than me. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 5, 2019 Share Posted February 5, 2019 DJP Link to comment Share on other sites More sharing options...
Rookie65 Posted February 5, 2019 Share Posted February 5, 2019 I was goofing around with this and what I found is that the sink in this situation places itself below the top of the cabinet. Even when I set the sink to be at the top of the counter, it sat below. May not be a bug other than the sink is set to default at a certain height. If you do a cut through view, you should see the sink "floating" in air in the cabinet. Then just change the height to where it needs to be and that should do it. Link to comment Share on other sites More sharing options...
Bretkennedy74 Posted February 6, 2019 Author Share Posted February 6, 2019 thanks everyone for the assistance. I have made my own little video here for you. It may be the bug for that vanity. floating_vanity.mp4 Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 6, 2019 Share Posted February 6, 2019 Your common denominator is the vanity cabinet you are stubbornly trying to use. If you abandon using that object and just use a standard cabinet, altered to appear (look like) the one you want you can then move ahead. Some sinks or cabinets made by other sources than Chief Architect Inc are not pre-programmed to work as expected and as you have seen. Use what works and abandon that which does not. DJP Link to comment Share on other sites More sharing options...
Bretkennedy74 Posted February 6, 2019 Author Share Posted February 6, 2019 As you can see in the background I did just that. I wanted to see if my assumptions were right in that the cabinet was indeed the issue and not my technique Link to comment Share on other sites More sharing options...
CourtneyM Posted February 10, 2021 Share Posted February 10, 2021 Did you (or anyone) ever find out how to place a sink in a pre-made vanity? I usually use the cabinets and alter them but I found a vanity I really want to use but I can not figure out how to place a sink in it. Link to comment Share on other sites More sharing options...
