Rectangular window w/arched casing
CJohnStanchina
Go to solution Solved by CJohnStanchina,
http://www.sketchup.com/
Sketchup is free, and you can model things in Sketchup and import them into Home Designer. There is also 3D Warehouse which is a library of models others have built.
If you do a bit of searching you will find info on using Sketchup with Home Designer.
I've just been using the program for a few months, so there may be an easier way to do what you need. Maybe someone with more experience will respond.
Thanks for turning me on to Sketchup, Eric.  I'll definitely play around with it.
Thanks to you as well, Eric for the workaround in HD.
Basically, I just need to be able to present a front elevation of the home that embodies our design vision and that passes the HOA's architectural review.
So again, many thanks to you both!
CJS
