pacs1963 0 Posted November 15, 2018 is it possible in home designer suite 2018 to create a coved wall to ceiling condition as shown in the attached photo? I tried using a coved molding , but I can't seem to modify the moldings' details to make it appear as a smooth transition. Thanks, Phil Share this post Link to post Share on other sites
DavidJPotter 203 Posted November 15, 2018 I Suite, The only way I can think of is to build roofs and then turn off auto-rebuild-roofs and then lower the ceiling height by way of a room specification dialog. You will have to plan this out so as to have the height of the roofs correct but that will only cove the ceiling edge where they meet the roof planes. In terms of symmetric applications, there is no solution that I know of with Suite. It has VERY limited abilities compared to Home Designer Pro or Chief Premier. I suppose if you are really intent on doing this, you could download a copy of Sketch Up, learn its tools and then make whatever you want for importation into Suite or other HD programs. DJP Share this post Link to post Share on other sites
pacs1963 0 Posted November 15, 2018 Thank you David. I do have sketchup pro. I did not realize I could import .skp files to HD Suite. Share this post Link to post Share on other sites
