jlliles87
Wall Covering Not Displaying
I'm working on a plan and trying to get the wall coverings in the gables to be most of the way up the gable similar to this sample picture I've attached. After adding a wall covering in the gable, it won't display. I've never had this problem before (also never tried to do a look like this) so I'm sure I have a setting wrong somewhere.
While I'm creating a thread, I've also struggled with the overhang/roof return that runs along the left side of the porch. I'm getting much more comfortable with manual roof tools, but modeling this part is a bit over my head at this point. It's just sloppy the way I have it right now but any help on how to create this look would be much appreciated.
TERRY TEAT.plan
I've modeled that same plan -- don't remember why or when.
You will probably need some manual roof work to get it correct.
I opened your plan in Pro 2016, where the wall covering did not show up, and in the latest Chief Architect Premier, where it did.
Suggest you use a Pony Wall, or Custom Backsplash, instead of the Wall Covering.
