Open Corner Shelves
dbritti
I'm trying to create open corner shelves like in the attached picture.  A corner tall cabinet with doors removed and with the "diagonal" option unchecked almost gets me there, but it leaves center stiles (or vertical frame pieces) in the front where the two sides join in the middle.  Any way to get rid of those?
Thank you!
Denise
Using MacBook Pro, High Sierra
Home Designer Pro 2018
I see you said Pro, but you can help everyone (including yourself) by adding this info to your signature (see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left.
Doing so makes it always available, and keeps others from having to hunt for it.
And, turn on signature display too.
Resources for self help:
You could build out of parts -- partitions, and slabs or countertops for the shelves, or push 2 cabinets together (which look good in Standard render, but not Vector views). Uncheck Create Automatic Blind Corner Cabinets if using the 2 cabinet method.
Looks like you are correct. Making them from parts is fairly easy.
Make a shelf -- you can't use the shelf tool as it only does rectangular shapes -- then use Transform/Replicate to copy them and move in the Z axis.
